dougrainer
Jun 29, 2015Nomad
1. You have a CONVERTER, not an Inverter,
2. The LED lights light up when either the fuse is blown or pulled and there is a 12 volt LOAD on that circuit. So, if the LED for the refer did NOT light up when the fuse was pulled, that indicates the refer is NOT connected to the 12 volt power fuse. Find out if there is 12 volts to the rear of the refer. It requires 12 volts to operate whether on 12 volt/120 /lp. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
