mike-s
Sep 27, 2016Explorer II
If it works on electric but not propane, it's an issue with the gas system. The only difference between the two is how much heat they put into the system.
Assuming it used to work fine, have you pulled the jet and soaked it in alcohol or carb cleaner?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
