dougrainer
Oct 02, 2016Nomad
maxum1989 wrote:
I thought I should update this in case someone has a similar issue.
After giving some serious thought and staring at the fridge for a while I determined that the flame size/intensity had to be the issue. The baffle and flue were crazy clean and the flame was burning so that had to be it. So I cleaned the jet again. This time I let it soak for hours in alcohol. Last time was about an hour. Well, it worked. I just got back from a 3 day road trip and the fridge has never worked better. It was even cycling on propane. So, if you have a fridge on propane that has a flame but just can't keep the temps down, check your propane pressure and then clean the heck out of the jet.
I never soak a orifice. I ALWAYS blow out with compressed air and in 37 years have never failed to get the orifice opened up. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
