Chris_Bryant
Jun 23, 2017Explorer II
WesternHorizon wrote:
1995 Class C, maybe original fridge. Has worked well but out in the heat and now the fridge won't get cold. Freezer cold.
Found this thread
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23866404.cfm
OK, I unplugged the thermistor while unit on gas. When I unplug, I hear a thunk and replug hear another. Presumably the gas valve. So does this mean the thermistor is good?
I am running the generator now for AC test as directed in the trhead but it seems like the test above implies the thermistor is good.
Any tips appreciated!
Unplugging the thermistor tells the refrigerator it is too hot, so if you hear a clunk when you unplug it, but it is not cold, the thermistor is bad, otherwise there would be no difference.
Try running it for 24 hours with the thermistor unplugged.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
