WesternHorizon
Jun 23, 2017Explorer
Old-Biscuit wrote:
Sorry but unplugging the leads of thermistor (temp sensing device in food compartment on far right fin) will cause fridge to run/cool continuously----failure mode from lack of temp sensing.
Freezer section 'cold' and food compartment NOT COLD......blockage between freezer evap coil and food compartment evap coil.
Cooling unit is DEAD. NO Good...will NOT cool
It's a TEST suggested in the post that I cited. A TEST is not continuous operation.
UPDATE: Running overnight on GAS with the thermistor unplugged... the fridge is getting cold.
This implies the thermistor may be bad. I will check resistance when I get home.
Has anyone replaced the thermistor? Can't find any info on this.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
