rvman69
Jun 20, 2023Explorer
Dometic RM2652 no power to upper control board
This is a Dometic RM2652 about a 2010 maybe a little older. I just got done putting in a rebuilt cooling unit. Before I put the cooling unit in I could turn the power button on the control panel on and the LED light would come on. Well after I got the new cooling unit in and the fridge back in its place and all hooked up. When I turn the light switch on I get no LED light like there is no power there. There is no heating element in it at this time. Pretty sure it should work on gas without having heating element installed. I do get 12 volts from the power lug up to the thermal breaker and across it. Then from there to board in back. The light in the fridge does work. It's like it is not getting 12v up to the upper control board. What is the best way for me to test power getting up to the upper control board? I was careful with the wires that go up to the top of the fridge and inside. But anything can happen I guess. Thanks
