rvman69's avatar
rvman69
Dometic RM2652 no power to upper control board
This is a Dometic RM2652 about a 2010 maybe a little older. I just got done putting in a rebuilt cooling unit. Before I put the cooling unit in I could turn the power button on the control panel on and the LED light would come on. Well after I got the new cooling unit in and the fridge back in its place and all hooked up. When I turn the light switch on I get no LED light like there is no power there. There is no heating element in it at this time. Pretty sure it should work on gas without having heating element installed. I do get 12 volts from the power lug up to the thermal breaker and across it. Then from there to board in back. The light in the fridge does work. It's like it is not getting 12v up to the upper control board. What is the best way for me to test power getting up to the upper control board? I was careful with the wires that go up to the top of the fridge and inside. But anything can happen I guess. Thanks
  • No delay. It should be immediate.. and it does it multiple times if it does not detect flame. If it does not succeed then the check light will come on.
    If you have a dvm, put it on 20 vdc and put the + lead on the incoming signal wire to the igniter and see if it provides a 12vdc signal. If it does then check the spark wire ceramic part of the electrode to see if you might have shorted it out or if there is even a fingerprint on the ceramic it will use that as a path to ground and no spark. In other words it could be sending a spark but it is getting shorted to ground somewhere along the way to the tip of the electrode. If the electrode is too far away from the burner it will not spark. 1/4"....
    Jim.
  • I got it figured out. When I first realized the cooling unit was bad for sure I messed with the two far left red wires before I took a picture. I know better than to do that. I dont even remember why I took them off now. Well when I put them back on before I took the fridge out I put the 12v coming from the 12v block to J3 instead of J1. So that is why I had light inside the fridge. J3 and J2 are hooked together and are feed 12v from the board. So the way I had it hooked up the only thing on the board that had 12v was the interior light. Now to the next issue. I dont have a heating element in it yet. (It is suppose to be here tomorrow) I have the fridge plugged in and I go in and turn it on. Then I come out and unplug the fridge from 120v to test the gas part. It does its thing and then the gas valve opens and I can hear the gas coming out but the ignitor did not fire. Any ideas what could be going on there? Is there a delay before the ignitor fires off after the gas valve opens? It worked before but we dont use propane very often. Basically just when we travel from home to campground. Thanks
