Travelin2 wrote:
Last night I set the fridge to electric(Auto) and unplugged the thermistor from the board. As you can see it got very cold inside the freezer and refrigerator compartment. I turned it off and opened the doors to let things get warmed back up. In a awhile I will restart it on gas and see if that session on electric woke something up. I can't figure why it didn't cool on gas when the flame seemed to run so nicely.
OK now you know cooling unit is functioning correctly
Propane should do the same provided:
*LP Propane System Pressure is 11"WC (0.4 psi) ----10"WC (0.36 psi) will still produce a clean blue flame but that 0.04 psi difference will NOT produce same amount of HEAT needed to transfer to boiler section
*Flue/Flue baffle rusty---can't absorb/transfer required heat to boiler section
*Flame should reach just inside flue opening and be strong/steady flame---BLUE
