ktmrfs
Nov 11, 2020Explorer III
cavie wrote:
Gas/electric fridge requires 120 and 12 volts to operate. 120 is for the electric heating element. Gas is for the gs heating burner. 12 volts is for the control circuit for both. If the interior light is out you have cost 12-volt control power. Time for an RV tech.
120V is only needed if you want to use the electric heating element rather than gas. But 12V is always needed.
check the fuse in the power center as well as the two fuses on the dometic controller board. I had a similar problem a few years ago and discovered that one of the fuses on the dometic control board had opened. BTW the fuse was an odd size, not a std 3AG glass fuse.
