David_and_Deb's avatar
Nov 11, 2020
Dometic RM2652 refrigerator dead
I just noticed the light inside the refrigerator is off as is the light on the outside of it. Everything else in the motorhome is working and powered as we are dry camping. Turned the generator on and it still didn’t come on. Checked the propane and it is half full. House battery is working. We are level. Stumped. Any ideas?
  • I am not familiar with the Dometic, as I have Norcolds. Anyway heres my first guess. Do the 120v outlets work, maybe the gfi that the frig is plugged into is tripped. Check both the 120v breaker panel and the 12v fuse box. My Norcold on the outside access door has a circuit board with two fuses maybe the Dometic has the same type of set up. On the Norcold it takes both 120 and 12v to make it work maybe Dometic is the same.
