ksg5000
May 11, 2017Explorer II
Do you know what model refrigerator you have? As I recall my original fridge on my 91 fleetwood wasn't manual as indicated by Chris but a 3 way. If you know the model you might find the service manual on Chris's website http://bryantrv.com/docs.html
At any rate - you fridge probably has a manual valve which turns on/off the gas ... make sure that's turned on. There is likely a burner assembly which has a burner tube with an electronic igniter attached .. that can be removed and cleaned (probably filled with rust from the metal burner vent that runs to the roof). While it's out consider cleaning the igniter contact with some emery cloth.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
