homer1951 wrote:
Did you make sure that the element is working? (Is the burner tube hot to the touch)If not, try it on propane for a few hours and see what happens. If it is hot then the cooling unit could be blocked from sitting over the winter. If you can't take the fridge out and "burp" it to stir things up, sometimes just taking it for a long ride on a bumpy road will be enough to get it circulating again. If that still doesn't work, the cooling unit might have to be replaced
Cooling units cannot get blocked or fail from just sitting. It takes circulation of the Ammonia mixture at an off level or blocked ventilation to block or ruin a cooling unit. Doug
