30safari's avatar
30safari
Dometic rm3862 getting no power
I have a Dometic rm3862, it is getting no power. I thought it was the control board so replaced it with a dinosaur p-711 and still nothing.
Im getting 120v at the AC terminals but 0.9v at the AC out terminals, I'm getting 12v to the 12v+ terminal. But I'm not getting any volts to the interior light.
It's a brand new board and I have continuity at all the fuses.
Any ideas?
  • Follow the 12VDC+ (RED Wires)
    At Terminal Block (item K)
    To Thermal Fuse (item Y....near burner)
    To Thermofuse (item U...switch on burner stack)
    To J4 terminal on Circuit Board
    Check that the 12VDC- (Black Wire)
    from Terminal Block to Ground is clean and tight
    IF you have 12VDC+ at J4 Terminal then check the 3A fuse...far left...is good (test for 12VDC on both sides of fuse...not just look at it
    Wiring Diagram
    As for that Dino P-711
    Did your Original board part number start with '385' OR '293'??
    Not a correct replacement for Black Box '385' boards
  • Look on the side of the metal cover of the burner flue tube. There should be a Snap disc with 2 wires. THAT if tripped or bad will not allow 12 volt power to the control board. You wasted money on the Dino board. Doug
    PS. 120 power is only for the 120 heat element. Nothing else as the controls are all 12 volt
  • Sounds like a blown fuse.
    You should have a 12 volt DC distribution panel. It is commonly located adjacent to the 120 volt circuit breakers behind a metal cover held in place by a thumb screw. Test fuses with a 12 volt test light or volt meter.
    Make and model of rig?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
