craig_evans
Jan 10, 2018Explorer
Nina could be right. I just replace the board on mine and then found that the wire running through the ceramic insulator had come loose from the sensor. It was working just the way you described and wouldn't re-ignite reliably. Fortunately, its not that expensive, and luckily, there was one available in Canada from Dometic!
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
