enblethen
Jan 10, 2018Nomad
Two items could be an issue.
The ignitorprobe could be bad along with it's high voltage wire. This would stop the refer fromlighting and then shut down because the flame sensor didn't see flame.
Next would be the thermo couple. If not directly in flame or the burner is covered with debris from the stack.
Start by cleaning the burner area. Clean the thermo couple with steel wool.
Inspect the porcelain electrode for any cracks. inspect the high voltage lead for any nicks abrasions in insulation.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
