tri5ron
Jan 23, 2018Explorer
Old-Biscuit wrote:tri5ron wrote:
Thanks for all this info so far. You guys are great.
The product number for this fridge is
921146004.
I probably won't get back to the fridge until tommrow or over the weekend.
Then it has a thermocouple for flame sensing AND a spark electrode for ignition
Thermocouple has to sense the flame lit otherwise the circuit board shuts down DC to Gas Solenoid so raw fuel doesn't accumulate in burner area
Thermocouple tip MST be engulfed in flame when it lights off
Thermocouple MUST be clean...no soot/carbon build up
Thermocouple MUST have a clean/tight connection
Thermocouple should produce 25-35 Millivolts to lower board when heated (Lower then 18 millivolts will cause erratic flame operation)
Thank you for the info,
I have not been able to get back to this thread (or the fridge) until now.
I will go check to see if there is carbon build up on the thermocouple and that it is engulfed in flame (if I can get it to relight now).
If that is not it,... Can anyone tell me m
Where to order the parts from ? Possibly provide any part numbers ?
Thanks
