dougrainer
Jan 20, 2020Nomad
Since the 2 blue wires jumped and it does the same malfunction, the Tstat is GOOD. There are only 2 parts left. The Hi limit, which you bypassed. Result, The ignition module is bad. This is not a uncommon fix when you have your symptoms. The thing is to do what you did. Verify the other possible components are good. Doug
