wjoef
Jan 23, 2020Explorer
Took the furnace apart, tested the coils, and the gas valve, and everything works.
This RV started out as my mom's beach house. When it was new, right off the lot from the factory, she had water heater problems. As in, it would throw a FL fault and not work, but the electric heat worked. She had a RV Tech come out and look at it and he charged $400 (?) to change the control board on the water heater with a pronouncement that everything works now. She never used the propane to heat water after that time. Later in the season she assumed that the propane tank was empty and that's why the furnace wasn't working.
So, if you haven't guessed, I have had an AHA moment with this RV. There is something wrong with the propane distribution system. The water heater doesn't work on propane, the furnace doesn't work... What they both do is slowly flame out from propane starvation...
I have 11"wc propane pressure at the supply line to each appliance. Now I'm wondering if the tank was properly purged when it was initially filled.
Any other thoughts about why the gas flow doesn't keep up with demand? Do I just tear it all apart and blow air through the lines to clear any debris?
