DrewE
Jan 23, 2020Explorer III
Do you have the proper pressure at one connection when another appliance is and has been in use for awhile? Does the stove exhibit the same symptoms when it is on for awhile or when the furnace or water heater are used simultaneously? The stove is not a great tester as it has its own secondary regulator (usually), but of it gives similar trouble it's pretty telling of there being problems with the propane system.
My first guess of a culprit would be the regulator. Debris in the lines would sooner cause clogged orifices than impede flow sufficiently to cause trouble. Air in the lines I think ought to have been worked out of them by now. I am not an expert on these things, however.
If the RV uses portable cylinders rather than a permanently installed tank, try shutting the valve on the cylinder and reopening it very slowly.
