dougrainer
Jul 03, 2018Nomad
I think you hooked up the new capacitor wrong. The fact the compressor runs and blows warm shows you need a new upper unit. It has either lost its coolant or the compressor is not pumping. Either way you need a new upper unit. I would replace the upper unit, then see if you lose the error code. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
