N-Trouble's avatar
N-Trouble
Dometic took a dump - leaking refrigerant
I have a 2004 Weekend Warrior toy hauler with Dometic fridge that tooka dump last week. I opened up the back access panel and found refigerant (bright green color and smells of amonia) had leaked out. The leak looked like it originated inside the burner area so I removed the cover pulled back the insulation and found everything inside to be pretty rusted out.
Question is whether this is repairable or am I goign to need a whole new fridge. WHat am I looking at $$? This sucks because I was getting ready to sell the thing this spring to upgrade to something bigger.
  • Here is a video showing replacement of cooling unit........LINK
    Here is the place to get a cooling unit.....great company/great customer service. Talk to David Force......LINK
  • The cooling unit went our on our old 5er. Limped through the weekend with a cooler. The following week we figured out what was wrong, ordered the new cooling unit, installed it, and were camping the following weekend. Total cost about $500.
  • Going to a residential means adding and inverter and probably upgrading your entire battery system.
    I have helped friends replace cooling units, it cannot be done through the access. You will need to pull the fridge from its mounting (not all that difficult.) Then you need to remove the cooling unit, the cooling unit is the entire back of the unit from the freezer on down.
  • Dog Folks wrote:
    Upgrade to residential. Cheaper and a better refrigerator.
    How do you run a residential unit off of propane?
  • enblethen wrote:
    Cheapest is a new cooling unit.
    It maybe possible to find a replacement working fridge at an RV salvage yard.
    Depends on model for price. Cooling unit about $700 new about $1200+
    Used about $250
    Thanks I found the following site that sells refurbished cooling units. http://rvcoolingunit.com/Default.aspx
    My only question is does the refer have to be removed to replace the cooling unit or can this be accomplished through the outside access door?
  • Cheapest is a new cooling unit.
    Used about $250
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
