groundhogy's avatar
groundhogy
Dometic/Atwood Furnace AFMD30... grrr cntl board
So as we discussed in another thread, i pulled the stove out and went to work cleaning lint out that may have been blocking air flow. I had complained of the flame cutting off/on during cycle.
I cleaned around any slatted vents in the enclosure.
I went outside, pulled the plastic cover, pulled lint out there. Also had one of those cheap $1 little paint brushes handy and used that to brush off static dust.
FURNACE NO STARTY....
Today i troubleshooted it to the control board.
12v is on the wire that plugs into board.
But when i attach it to the board, its zero volts.
No action on the little red LED.
Do you guys agree that its the board?
What Dinosar board do i order?
  • Check the style of high voltage lead. That is main difference. Next is a resistor that is cut in some application that delays ignition. For testing, you would have to wait for 20-30 seconds before ignition sequence.
  • Yes. The one in the water heater was harvested from my last Suburban furnace.
    I had to cut that resistor lead when i installed it in the water heater.
  • If you are talking about the 2 red wires with spades on the board? 1 Wire is smaller gauge than the other?. That is the connection for the Fan motor. It does not really supply voltage to activate the board and LED. The side board quick connect is what powers the board. The BLUE wire should have 12 volts when the Tstat closes. Check for that and then see if the LED light blinks or comes on. Doug
  • Dougrainer:
    Ok will look at that.
    Also I called Dinosar. He also said the12v on the separate wire is to power the fan.
    He agreed that the PC board drawing down the 12v without some part on the board shows high resistance in that line. I will also check the 12v fuse box for corrosion.
  • SOLVED:
    It was the thermostat.
    Now.. one of the first things I did was bypass the Tstat by shorting those two wires together. So..??
    But here's what pointed me back at the thermostat.
    I drove the truck around next to the furnace. Got out the jumper cables.
    I injected my own fake 12v call signal to the control board.
    Saw a spark and the fan popped on.
    I removed the fake 12v. Furnace left blower on for about 1 minute and back off.
    So I pulled the Tstat (2-wire plus some anticipator thing that I didn't think I used.) and started trying to figure out this chinese puzzle of little contacts and plates.
    Turns out the antipator is in the circuit.
    The anticipator looks like a little round circle of (thermal?) wire with a little arm that you can put at any position around the circle to create different ... anticipation times.
    This little arm needs to be ON the wire circle. NOT in the parked neutral position.
    Somehow the little arm ... maybe vibration?...had gotten to the parked position.
    The continuity back to the furnace seems to go through the anticipator.
  • And how this Tstat problem decided to give me BS EXACTLY at the same time I was cleaning lint out of the air slats.. IDK
    What usually happens is you overload or short the tstat 2 wires to that metal tstat. It BURNS out the anticipator and then the tstat does not work. Did you also blow out the tstat itself and that could have moved the tab for the anticipator? Doug
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
