NanciL's avatar
NanciL
Explorer II
May 23, 2014
Don't use Bristol Sink basket strainers
I replaced the two basket strainers today in the kitchen sink and I will never use ones made by Bristal again.
It took me longer to get the shrink wrap that seemed to be glued to them off then it did to do the whole job, and some of it on the underside would not come off at all. Then I had to reuse the large rubber washers that came with the original ones, since they didn't include them.
I got this at Campers World, and if I hadn't already opened them up, I would have returned them.
Jack L
  • I bought strainers that fit a bar sink, matched perfectly.
  • Almot's avatar
    Almot
    Explorer III
    Gdetrailer wrote:
    Typically a new basket at Lowes or Homedepot will cost $2 or there abouts which is most likely a lot less than Camping World..
    If basket is same size. I didn't have to replace the basket yet, but RV use a weird 1.5" pipe. It is 1.5" ID but a thinner wall than a standard residential 1.5" pipe, so all the fittings are different from residential. It's only after the drain elbow when it becomes a normal size plumbing. I think they did this on purpose, to keep a price monopoly on weird plumbing.
  • Camping world has always refunded anything that didn't work for me, wrapped or not. I wouldn't hesitate to take them back. No way for you to know if they worked unless you unwrapped them. Besides, they need to know when they are selling junk!
  • You do realize that you can often find nearly every size basket strainers known to man kind at your local Lowes or Home Depot?
    Take your old basket to one of the home improvement stores then match the size..
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
