Turn_Key
Jul 16, 2015Explorer
Thanks, Dick. That's the kind of info I need. I had thought that the Doran system was rather new but I'm pleased to hear that it has been around a while. Helps to give me more confidence in it. Also, you say that a sensor will drop out and then shortly return, on occasion. Could you tell me if you are equipped with the signal booster that Doran speaks of?
Also, thanks to Ed and I will look into the TST system before I make a decision.
Have decided to add tire sensors to our new rig due to experiences with our last "5th", a 29' KZ. Had it 11 years and it was great for us. We did have 2 "tire" episodes over the years. Had one "blow out" on our way to Arkansas one morning. Did some minor damage that I was able to fix on return. Second experience was a bit more interesting. We were returning from the Texas Hill Country on 281 one morning about 10AM. Had pulled to the side of the road to use the "facilities" and, as always, I did a "walk around". As I passed the "curb side" tires, I heard a very faint "hiss". Now, I'm an old man with way too many years working in machine shops and know that my hearing isn't that good, particularly with all the road noise and wind blowing out there. None the less, I checked and sure enough, the rear tire had a very slow leak in it. When I put my gauge on it, it was only about 10 lbs. low. That told me that it had just been punctured. I have road service but was able to do it quicker myself. I have always known that I am being watched over and this just further convinces me.
Our new rig is approximately the same size and weight as our KZ but has larger tires running at 80PSI as apposed to the 65PSI that the KZ ran on. I feel confident that our Winnie will carry the load easier but still, I think the tire sensors will be a good addition. As I said above, I am convinced I have an extra "passenger" at all times. I'm just not willing to expect more from that passenger then I have coming!
Thanks for the help and Happy Camping!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
