Roger10378
Nov 02, 2022Explorer II
There should be 2 wires(probably blue) from the furnace to the controller. They need to go to the thermostat. The thermostat is just a switch that connects the 2 wires to turn the furnace on and disconnect the wires to turn the furnace off. You can test the furnace by connecting the 2 wires at the controller and the furnace should work. If the furnace works just extend the wires to the thermostat(common and heat) and you should be good to go.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
