- HslagExplorerThere was a start capacitor and a not here one the bigger one looked like it had been leaking acid
The smaller starter capacitor had a burnt spot on the top I think I found the issue! Hslag wrote:
There is voltage to trailor my plug ends work . Yes circuit breakers are not tripped and no fuses are blown
ALWAYS turn the 120 breakers OFF and then ON again when checking. They can trip and they look like they are not tripped. Doug- HslagExplorerThere is voltage to trailor my plug ends work . Yes circuit breakers are not tripped and no fuses are blown
Chris Bryant wrote:
Did you check the circuit breaker?
AS noted, your controls are 12 volt and that is the click you hear. The Fan and Compressor must have 120 volts. So, no 120 to the unit or AC and the AC will not run. Doug- Chris_BryantExplorer IIDid you check the circuit breaker?
- HslagExplorerI well check
- 1492ModeratorMoved from Forum Technical Support
- lj2654Explorershould have a round canister on roof unit....check to see if it is swelled up at wire end...if so replace...start capacitor
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
