pianotuna
Mar 30, 2015Nomad III
double conversion problems
Hi,
For years I've been using double conversion to power my RV when there is limited shore power. I had a 2500 watt Cobra MSW inverter.
Tonight, because a GFI on the house shore power was tripping, I decided to plug in the 9100 PD9140A and then use the Magnum 3000 inverter to power one dedicated outlet in the kitchen.
Initially it worked as it did with my old MSW Cobra. But that didn't last. I think (too dark to see) that the reverse polarity fuses on the 9100 PD9140A have blown. I'll dig into this tomorrow.
The Magnum was not connected to shore power. I did not have the RV shore power connected to it.
If it is the fuses then I am thinking I will replace them with manual reset circuit breakers.
