cdnmacgiver's avatar
cdnmacgiver
DPDT Switch for Battery Bank
I have a WFCO Converter (110 to 12) and a power panel (12V and 110v) with my travel trailer. One side is fed 110 v and the 12V panel is fed from the single 12V battery on the trailer tonque. I am installing a 2 battery (6V X2) battery bank under the sette with access to the outside that is getting charged from a solar panel and charge controller. I thought of rerouting the feed from the 12V tongue battery (supply to the power panel) through a DPDT switch. 6V battery bank or tongue battery to the power panel. I have already a isolation switch from the charge controller to the 6V bank. Any suggestions where to get a dpdt switch or could I use two battery selector switches (off/on 1 or on 2). Thanks
  • In the first gentleman's reply he had a diagram showing the 6V battery banks were grounded. In my case the 12V tongue battery (both + and - ve) wires go to the connectors on the 12V power panel. I was going to cut the wires and add two wires from the 6V battery bank all terminating at the switch. Seemed to be the most easy thing to do. My trailer does not use a ground -ve except I believe for the brakeaway switch as the terminals exit from the battery box. The switch is right there on the tongue. Thanks again. Thought using two off/on battery switches from blue seas would work.
  • Use the battery switch on the positive. No reason for DPDT to switch the negative side.
  • RoyB's avatar
    RoyB
    Explorer II
    I use these BLUE SEA multi-position sealed high current battery switches. There are many marine qualified similar units out there but this is the one I have used over the years...
    Mine is a four position high current selector switch. (OFF-BAT1-BOTH-BAT2)
    The big reason i selected this switch is being sealed and also has MAKE BEFORE BREAK switch contacts inside to prevent internal switch arcing under load.
    I don't use these for any solar application but here is my general setup on using three of these switches with four GP24 batteries. Gives me two banks of two each batteries where i can switch to one or all four depending on what I want to do at the moment.
    These are a couple of drawing using two or four 6VDC batteries in series using these switches...
    Might give you some ideas on your application... I have never looked for 2P2T such high current switches before from BLUE SEA products...
    Roy ken
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
