lanerd's avatar
lanerd
Explorer II
Nov 14, 2013
Draining large quantites of motor oil
My Cummins ILS holds 28 quarts of oil (7 gallons). The largest container I can find that is used to drain the old oil into is only 5 gallons. What do others use so that you don't have to use two containers?
Ron
  • Ivylog's avatar
    Ivylog
    Explorer III
    Not the answer you wanted, but the easiest is to use two 5 gallon buckets moving the first one when only half full so it's easy to slide the second one into postion. With the half full one under the filter, punch a hole in the bottom of the filter and come back in an hour when it and the engine are finished draining..
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
