BFL13's avatar
BFL13
Explorer II
Dec 17, 2013
Drawing or Charging From Different Batteries in a Bank?
I can't remember (if I ever knew) why you are supposed to have the loads and the chargers all on the same battery posts in a bank.
Say you have three 12s in parallel. What's wrong with having an inverter wired to one of the 12s, the converter to another of the 12s, and a second inverter on the third 12? Also you might have one solar controller on any one of those three 12s and another controller on a different 12.
Ideally everything should be balanced and you put all your goodies "across" the whole bank. But what if you have short wires and that is just not possible or convenient? What terrible things happen if you "tap" in or from any place you can get at?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
