Stevec4s's avatar
Stevec4s
Dreaded EE code
Hello all,
I need help with Ac. I have the 5 button duotherm. I have replaced the thermostat, one communication cable that was bad and the control board. Actually two of them. I have tested both communication cables the one going to front ac and the one to the back ac. Both are good and wired correctly. My units are the older penguin heat pumps. What am I missing turn thermostat off press the two buttons get the FF then release and get EE.
Have checked the 12v and 110v and all good. All duotherm said in email is you have communication error. I Know that but why? Help!
Thanks in advanced!
  • OK, you stated you swapped P connections on the Control board? Then it showed Zone 2 and Zone 2 functions? Did you have Zone 2 control board COMM cables connected at this time? Now, LOOK inside that P connection that did not work with a flashlight. Do you see any corrosion at all? You may have to remove the Galvinized cover on that box to get a complete look at the PC board. Check for corrosion on the board. There are 12 volt wire connections----BLACK and RED. Which Zone Board has the Black and Red connected to 12 volt power? The one in your pic(Zone 1)? The ONLY way Zone 2 would show up on the Tstat is if the DIP switches have Zone 2 turned on on the Zone 2 Board. The DIP switches are those white switches on that red block. IF you turn the DIP switch to Zone 2 on the Zone 1 board, then the tstat will show Zone 2. Zone 1 is the default Zone on the control boards and does not have a DIP switch. Last I asked for Year/Brand/Model RV. I need that. Doug
  • I have a 2005 Monaco Diplomat PDQ Sorry I thought I posted that earlier. Terminals have been cleaned with alcohol. All good there. It seems P1 is the culprit. When I unplug p2 going to the rear unit I get EE code again. Plug back in and see zone 2
    The only pin switch in zone 1 that is on is 5 for the furnace. My 12v goes to my front unit zone1
  • Plug the tstat into P2 and unplug the Zone 2 comm cable. You CANNOT clean the small pins in a Phone type connection if corroded. If you go to the bedroom Control board you will see Zone 2 DIP switch ON. What you can do is easy if the P1 is bad. SWAP the front and rear control boards. Put the NOW Bedroom Control board to Zone 2 and the furnace ON. Put the now front control board to Zone 2 OFF. You should now have the P1 and P2 operational and connect the bedroom Zone 2 COMM cable to the working P2 of the old front zone board. Doug
  • BTW, A Tstat reset (FF/EE). All that does is verify the DIP switch settings and communication between the tstat and the Zone control boards. Nothing else. Doug
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
