MrWizard
Oct 04, 2018Moderator
Mex
if there is almost no water flow in the afternoon from the pipes
i think the only 'way' for the pump will help
is if you place it at the output of the water heater or in that water line inside the house
once the tank is pumped empty, the reservoir is gone,
i'm not sure the pump will help with low pressure from the city side
if there is low flow from the city side
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
