catmancando's avatar
catmancando
drilling into frame
I was thinking of drilling some holes in the frame of my tt and mounting a length of pvc pipe for my sewer hose I know I could not do this on my semi truck but what about on a travel trailer:@
  • hey thanks to all this gives me more idea 's on mounting stuff to the frame
  • RoyB's avatar
    RoyB
    Explorer II
    When you look under these LITE TRAILERS and see how many large holes the manf drills in the frame to reduce overall weight should scare the H out of you then I reckon haha... Some of these holes I have seen are 4-inches or more in diameter.
    I have drilled many small screw size tap holes to mount brackets, ground lugs, fuse blocks, battery switches, etc... over the years in both my trailers and trucks...
    Who knows if you are not suppose to do this haha...
    Roy Ken
  • christopherglenn wrote:
    drill in the center of the frame. The top is under compression, the bottom tension, the middle just fills space.
    x2
  • drill in the center of the frame. The top is under compression, the bottom tension, the middle just fills space.
  • don't know will have to look at it more closely I don't want to weaken the frame so that seems like a better way to go
  • Is there a way to snake SS hose clamps around frame members, rather than drilling?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
