Golden_HVAC
Apr 27, 2014Explorer
Here is a picture of my roof, after coating it with a roof coating.
It shows the solar panels tilted while I am applying the roof coating. To get the wiring from the roof to controller, I used a coat hanger and pulled in grey #10-2 wire (home Depot) to run the power through. I have about 12 amps going through each of the #10 wires to the controller, and then #8 wire to the battery.
Good luck with your project.
Golden_HVAC wrote:rickthescot wrote:
Sounds like a great idea. I guess asking for pictures again is not going to persuade you though. We are visual creatures and I don't think 1000 words will accomplish what one image will. You can do it, just one pic.
More pictures that I took a few days ago to post pictures of my solar panels, and their mounts. Some pictures are really close up pictures of the solar panel mounts, and give a clear picture of howrough the surface is.Golden_HVAC wrote:
Hi,
This is my front pair of panels. 120 watt mounted on a curved roof, 102" wide.
This is the mount it is held on with three rivets into the frame, and then the bottom half is 6" long aluminum, with nutsert in the upper piece, bolt you can not see from the outside edge pointing inward.
This picture shows the bigfoot panel mount sold by RvSolarElectric for $35 a set back in 1994. I wonder what they cost today?
This picture shows the panels tilted while I was working on the roof.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
