brulaz
Apr 28, 2014Explorer
westend wrote:
A guy could use a marine through-hull fitting for roof entry. They tend to have at least part of the fitting extending out from the mounting surface.
Can't access it from the inside, so has to be screwed down from the top. Ideally cable goes in at the horizontal and out at 90 degree angle down. Will browse around at West Marine tomorrow and see what they have.
Or, if the hole is tight around the cables, could probably just clamp the cables tight to the roof just before they go into it. And squirt gobs of Dicor all around and into the hole. Sounds ugly though ...
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
