Gdetrailer
Mar 19, 2022Explorer III
Generally you will have to replace the entire fixture..
I am not sure but E450 could be the same door as E250/350, if so you might be able to sub in a mirror assembly that is listed for E250/350. Generally as long as it is not heated or powered and the door has the same profile and mounting holes it may interchange.
Does it look like this?
If so, found non heated manual mirror assembly HERE for $164
