ktmrfs
Sep 25, 2020Explorer III
my issue with the unvented heaters (buddy etc.) is that for every gallon of propane burned you release 3+ quarts of water into the trailer air. If you are camping in an area with low humidity, may be fine. If you are camping in an area with higher humidity, the result can be fogged windows and condensation even with a vent/window open.
Same with the propane cooktop or propane oven.,
This is NOT an issue with the propane water heater or propane furnace since they vent combustion air outside.
