Almot
May 31, 2016Explorer III
CamperWill wrote:
We already have the inverter and it is indeed a pure sine wave as is the generator we've been using, I know how sensitive electronics can be.
MW can be sensitive but you likely won't be using it.
Sensitivity of laptop to PSW AC is kinda mute when it runs on DC output of the AC-DC brick plugged into inverter. Not to mention when you only charge it, for subsequent use unplugged. Which is probably the best way to use it, if inverter is small.
