time2roll
Jun 05, 2016Nomad
Naio wrote:Generally with PWM you will have 12v panels in parallel. Even a single cell shaded will reduce voltage below battery voltage and the panel drops out.on a PWM controller, Any shade disables charging on a single panel.Is that right? I knew about the bypass diodes, but I had no idea they didn't work on pwm.
With MPPT It will depend on the panel. if its has enough bypass diodes it can lose voltage and still charge a bit. so maybe :h
Bypass diodes are more effective in higher voltage panels or multiple 12v in series with MPPT. If a small section is shaded you may lose 10 volts but the rest continue to work because the total was 30+ volts when all is in the sun.
Yes there were some 12v panels with a diode across every cell but still does not take much to get below battery voltage.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
