CamperWill's avatar
CamperWill
Dry camping electrical questions
Hey all, so we've been camping for quite a while now and are starting to transition to no hook-up camping and have a couple of questions. We are looking to add an inverter and solar charging and could use some pointers for how to wire it all in.
The inverter (12v > 120v) we are looking to add is 1000W which is more then enough for the light loads we will be pulling through it. Now I'm familiar with both 120v and 12v wiring but I've never mixed the two. Am I right in thinking that the inverter can be wired into a spare 120v breaker with a lockout and we can just flip it on when dry camping as well as turning on the inverter itself? I'm guessing the stock power converter may decide to start charging the battery since a 120v input will be detected so what's the best way to deal with this?
As for solar charging, based on my calculations a 100W panel should be enough for our needs. Any tips on wiring this in? Any recommended kits? We have a couple hundred to spend on this.
