the_bear_II
Jul 18, 2014Explorer
If you are conservative with power use and have a single battery you can get by for 3 to 4 days.
You need to use flashlight and lanterns to keep from using the overhead lights. If the trailer is equipped with an inverter and microwave...only use the microwave for very short duration heating. No 30 minute cook times...1 to 3 minutes only.
The water pump, heater, refrigerator, TV and other appliances will be the biggest users of power. Make sure to use propane for the refrigerator.
Use paper plates and plastic utensils to save water and pump usage by not having to wash a lot of dishes. Take navy showers...look it up on google.
If needed, and your tow vehicle is wired properly you can plug into it to recharge the trailer battery by letting the engine run for an hour.
Adding additional batteries and or carry a small portable generator will make it less neccessary to conserve power.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
