Golden_HVAC
Nov 05, 2016Explorer
Hi,
If you are running the generator that much, make sure that the ice maker is off. This has a 300 watt electric heater that helps thaw the ice during each 3-5 minute harvest cycle. Not only that, the ice maker adds a lot of heat to the freezer.
With a few 100 - 150 watt solar panels, you can avoid much of that generator run time. I would not buy the factory solar systems, they seem to be marking them up by at least 100% more than they paid for the panels and controller.
Look at this website. SunElec.comp
Look for some 12 volt nominal panels, and in the 100 - 150 (175 watt+ gets really large width and length). and a PWM controller. You might need a 20 amp controller for each pair of panels. It is OK to have more than one controller. MPPT controllers seem to put out more amperage, but in reality, they do not make enough extra power to justify the extra cost.
I installed my solar panels in my new 1997 Bounder, running the wires down the back of the propane refrigerator, to the closet mounted controller, to the basement, and the batteries. I have a 415 watt system on my 30' Bounder.
Drilling holes into your brand new roof can be difficult - but in reality, it is pretty easy.
I would want at least 600 amp hours of battery storage, in large golf cart batteries.
Samsung refrigerators seem to be the best pick, for use with a inverter. I would also insist on a pure sine wave inverter/charger.
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
