Rock2
May 28, 2014Explorer
Roman Duck wrote:
First, clean your burn tube. the smallest cobweb can deflect the flame, causing the flame out. If that doesn't work have the circuit board tested. Had same problems that we had, 1st time was dirty burn tube. Cleaned the tube and was good for the season. Following spring had same problem, wasn't the burn tube. Brought it in had it checked, board went bad. Replaced the board and works great.
Yes I did clean the burn tube with flexible brush. I even let orifice soaked with 90% rubbing alcohol. I pressed reset button. But it came out the same problem. The last thing I will bring circuit card to have RV tech to test it.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
