Old-Biscuit
May 28, 2014Explorer III
And that spark electrode is also used to 'prove' main flame
When the main flame ignites it generators a milivolt signal back thru spark electrode to circuit board telling circuit board I'M LIT. Circuit board then keeps power on gas valve keeping it open until t-stat opens killing circuit.
The spark electrode has to be engulfed in main flame
The spark electrode needs to be clean of carbon/soot
The spark electrode needs good/clean tight ground (the screw that holds bracket in place is the ground source)
The spark electrode ceramic can not be cracked
The spark electrode high tension wire needs good/clean tight connection to circuit board (wipe it down with a rag sprayed with silicone also).
AND the combustion chamber/exhaust tube needs to be clear of ANY obstructions
IF you still have problem with main flame staying lit.....then circuit board is bad
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
