Old-Biscuit
May 29, 2014Explorer III
dons2346 wrote:Old-Biscuit wrote:dons2346 wrote:
To add to Biscuits post, the connection between the brass nozzle where the gas emitted and the aluminum tube where the gas goes to is a slip connection which is very loose. This is where the millivolts gets transferred to the circuit board. It can get a little corroded and needs to be cleaned so there is a good connection. Put scribe marks on everything and take it apart and use some emory cloth to clean.
The circuit board is very reliable and most problems are caused by corrosion in the connectors ans this one slip joint
The flame proof signal goes back to circuit board via the spark electrode/high tension wire......not via burner tube.
There is current running through the burner tube, trust me. If that slip connection isn't a good one, you will get a flame out.
You may have stray voltage due to tube being in touch with spark electrode bracket (grd. source) BUT it has NOTHING to do with flame proofing....that is done via spark electrode & it's wire back to circuit board.
The circuit board is what provides power to gas valve and holds it open when it gets the flame proof signal.
No way for that stray voltage at burner tube to get to circuit board or gas valve terminals.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
