I read on a post that DTV is going to be dropping standard def. We have a King Quest antena which only support standard def. Does anyone know anything about this as I would need to change antenas if ...
Now might be the time to switch to Dish. As a long time Direct customer I can tell you service has deteriotated since ATT buy out. I suspect it will only get worse. The Genie2 has horrible software issues, and the Genie1 is not fsr behind. Scheduled fix is at least 4 months away according to Directv. As far as your antenna? You will need to check your owners manual or call the mfg to see if it could be changed to Dish if you choose to go that way.
