pnichols
Apr 17, 2019Explorer II
BFL13 wrote:MEXICOWANDERER wrote:
Good grade of AGM can withstand discharging to 30% soc but the maintenance for recharge must be as strictly rigid as a Trappist monastery.
This is where thick plates pay for their room and board.
With our camping routine doing 50-85s (approx.) with AGMs for a few days and then a two hour drive home, the alternator and solar charging during that two hours brings the batts up enough so they won't accept the required 20% amps.
Huge PITA to recharge them to full once home. Have to rig a switch to kill the solar and alternator for the drive home, or else as now, run the batts back down once home so they will accept the 20%.
The recharge to full at proper voltage to 0.5 amps per 100AH is no problem. It is that dratted 20% rule. And the battery spec sheets don't even mention it as a requirement. Only gives a max amps no min amps.
It's always something.
Hmmm .... I guess that you don't keep your Class C at home?
I keep my Class C in the backyard plugged in all the time with a float voltage on it's AGM coach batteries and a battery maintainer on it's engine battery. The coach batteries after a day or two of this floating always arrive at an acceptance level of less than 0.5 amps.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
