unsavory's avatar
unsavory
Dual batteries, DC to DC chargers, isolators, AGM... HELP!
Apologies for the long post, but I've been super impressed with the technical knowledge I've seen in on this forum and am hoping someone might be able to help.
I own a 2019 Jeep Wrangler, and have installed a Genesis dual battery system into it for running various accessories. The system is basically two 12v Odyssey dual purpose AGM batteries, with a smart isolator between them, that will automatically disconnect the accessory battery from the starting battery when a certain voltage is reached to avoid draining the starter battery, and then reconnect them when the vehicle is running for charging.
The problem I am having, is that I am not able to get these Odyssey batteries to charge properly in the Jeep Wrangler, because it has a very funky "smart charging system", that varies the charging voltage as you are driving to "save gas mileage". The voltage will fluctuate between 12.7v and 14.7v depending on the battery voltage and accelerator pedal.
Apparently Odyssey batteries only like to be charged at 14.7 volts for bulk charging, and 13.7 for float charging to top them off.
So now I'm looking into DC to DC chargers in order to get my charging voltages up to the correct level. Has anyone had any luck installing a DC to DC charger along side an already existing dual battery system that has a smart isolator built into it?
All of the DC to DC chargers seem to want the starter battery separated from the accessory battery, as they already have an isolator built in.
The other option I am exploring, is just disabling the smart charging in the Jeep by disconnecting the Intelligent Battery Sensor. But this causes the alternator to put out a constant 14.5v, and I'm worried this will actually OVERCHARGE my batteries... but I'm not sure?
Any other creative ideas I can try?
  • I had to do some quick reading about this system as I’m not familiar with it. It appears that it replaces the OEM battery with two AGM’s that have a smart isolator between them, correct?
    What was the OEM starting battery? Flooded, or AGM?
    A DC-DC charger could be added to keep the second battery charged correctly. It will do nothing for the starting battery though, so hopefully the Jeep’s charging system supports AGM. If not, I would not have purchased this system.
    IMO, a DC-DC charger could be installed between the starting battery and the second battery. But, it would need its own isolation solenoid (non-intelligent, not voltage sensing) on the input wire to the charger that is only energized when the engine is running. Otherwise, the DC-DC charger would continue to charge the second battery when the engine is off.
    Voltage from the second battery will not back feed to the starting battery through the DC-DC charger. It will boost the voltage going to the second battery though, and provided it supports AGM charging, will keep it fully charged. Let the Jeep charging system keep the starting battery charged, and leave the Genesis system intact so it’s fully functional.
    If the OEM starting battery wasn’t AGM, you might consider reinstalling it as the starting battery, and selling or repurposing the AGM.
  • You will not be able to use both the isolator and the DC-DC charger.
    Is the start battery floundering?
    Depending on your accessories you may want to go back to the oem start battery and DC-DC charge one or two Odyssey to be used for accessories only.
    Yep ! Pretty standard on almost every vehicle from about 2005.
    Follow the instructions ! What you are missing is that theses DC-DC chargers actually boost the voltage going to the second battery so that it get the correct voltage no matter what is being sent to the starting battery.
    DON'T DO IT ! The computer module is very smart and trying to trick it, is not a good idea.
    If the charging characteristics of the Odyssey AGM batteries are that different compared to a normal "flooded" lead acid, re-install a plain battery as your starting battery.
  • i have to say im confused. this looks like a custom designed product for the jeep? an expensive one that's for sure? i find it hard to believe they didn't design for this.
    that said if your just using the secondary battery and don't need it combined, then its easy, disconnect the second battery, connect the dc-dc charger to output of the second battery wiring from the genesis kit, and connect the output of the dc-dc to the second battery and that should be it.
