Old-Biscuit
Oct 04, 2017Explorer III
Assembly is slip fit/GLUED to drain pipe so you would have to CUT pipe into, shorten the pipe so you could use a coupling on each side with short piece of pipe to GLUE new assembly in place
Replace the valves via bolts in flanges.
I would unbolt the pipe side of flanges on each dump valve and remove as a WHOLE (valves and drain outlet still bolted together)
Then remove other bolts/valves...install new valves onto drain outlet and install as a UNIT--then bolt it up to drain pipes on each side
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
