otrfun
Jul 01, 2016Explorer II
joebedford wrote:Wow, very nice!otrfun wrote:Remove the thingy with the hanging lamps? I don't think the ceiling is open - the a/c vents into the ducts only.
We also have a Voltage. I assume your a/c unit is located, overhead in the main living/kitchen area. If you're not happy with the way it's currently cooling, I would highly suggest temporarily removing the ducted a/c ceiling assembly to see if your overall cooling improves.
Yeah, I see what you mean. It doesn't like you can do much if the a/c unit is mounted directly above the hanging overhead lights. Even if you gained access, the lights will probably obstruct any attempt to get any air-flow directly out of the a/c unit :(
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
